Old 21-Aug-2014, 6:19 PM   #9
nleahcim
Originally Posted by teleview View Post
Place the indoor RCA antenna in/at the inside of the of the patio window - door window.
Aim the RCA indoor type antenna at about 348 degree magnetic compass direction.
Here is how to aim indoor and outdoor type antennas.
www.kyes.com/antenna/pointing/pointing.html
Can also Test reception out on the patio with the RCA indoor type antenna.
The RCA indoor type antenna can be installed out on the patio.
If reception is good on the patio and you will like to continue reception with the indoor type antenna out on the patio , the indoor type antenna is not designed to deal well with weather/water and will quickly corrode.
Put the RCA indoor type antenna in a big plastic bag out on the patio.
A plastic garment bag is big. Or can use some other big plastic bag.
Can also install a , www.antennacraft.net , HBU11K antenna , or , AC9 , antenna out on the patio.
Aim antennas at about 348 degree magnetic compass direction.
You can drill a hole through the wall to get the coax from the patio into the apartment.
Or
www.hollandelectronics.com has a Flat Coax that will install as a pass through in a window or door.
Model number , 144823
Also , Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Hi - somehow I didn't see your post. Confused how that happened... Didn't even get an e-mail or anything... I think the forum may have hiccuped.
I have tried the RCA indoor antenna outside and I didn't notice any perceptible difference, surprisingly enough. So I think I need something stronger!
It looks like the HBU11K is rated for 40 miles and the AC9 is rated for 15-25 miles. So I think the AC9 will probably not work.
The flat coax you mentioned is interesting - I'll have to look into what is feasible for getting the antenna through the wall.
nleahcim is offline   Reply With Quote
