Old 21-Aug-2014, 4:20 PM   #8
Ben Myers
KD3WB
Originally Posted by nleahcim View Post
One more update... I noticed that every channel I listed above as being weak is now dead tonight, 9 hours later. Not sure what that means - guess my reception goes down at night? Or maybe some clouds cleared or something.
These are all in the same direction. I suggest you adjust the antenna to optimize these, then see if the rest are acceptable.
Also, I really want to get NBC - but I cannot even tune my TV to 11.1 which is listed in the TVfool report as NBC. What am I missing?
The virtual channels are created and stored in the television or converter when a signal is successfully received from the station. Not all devices can add channels after the original scan. Try entering "12", followed by a hyphen or period with the antenna pointed in the appropriate direction, or check the user's manual for the add-on procedure. If this doesn't help, you may have to do a complete rescan. Please be advised that you may lose any existing channels that are not received during the scan.
Ben
Ben Myers is offline   Reply With Quote
