Tv reception is weak signal strengths at your reception.
The tvfool report is not showing any antenna height above ground.
To see if reception improves at higher antenna heights above ground.
Do not delete the tvfool report that is not showing any antenna height above ground.
Please make and post 2 more tvfool reports with antenna heights of 25 feet and 40 feet above.
