Old 21-Aug-2014, 8:05 AM   #21
You're on the right track. A corrosion resistant grounding clamp sized to match your mast, some #10 AWG copper and an appropriate clamp to make the connection at the electrical service takes care of the mast ground. But you will also want to be sure to ground the coax shield... See http://forum.tvfool.com/showthread.php?t=901, post #20
