Just had the HBU33 relocated on the roof and onto a tripod. Went up 10ft more with the mast. Some channels improved but 13.1 did not.
Anyhoo......the person who installed it for me forgot to ground the antenna mast. I am assuming a grounding clamp at the mast with copper grounding wire leading to the service ground entrance would be correct?
He also informed me that the input & output connectors on the RCA Preamp that the coax connects to, both spin in their socket. I suspect the person who did the first installation, over tightened the coax fittings. Can the preamp be taken apart to hopefully correct this or is another preamp a must.
