Old 20-Aug-2014, 3:29 AM   #5
StephanieS
Greetings Sportsrock4374,
Not a desirable map, even at 80 feet.
Anything that would be suggested would be a shot in the dark. Your signal strengths all are below zero db. That puts you into extreme measures.
Any attempt with setting an antenna(s) up would require you to be fully aware that even with a properly functioning system, you may still have zero channels.
It's all up to you if you want to spend the money to try and see what you get. There have been times people have reported TVfool maps aren't the most accurate with below zero db signals.
If you do try, make sure you have decent options for returning the gear.
Cheers.
