Thread: antenna advice
Old 20-Aug-2014, 1:11 AM   #2
The ANT751 antenna will most likely work Ok at your reception location.
The ANT751 antenna is designed to receive the VHF high band channels 7 thru 13 and the Current UHF band channels 14 thru 51 the best.
Your reception location does have 1 VHF low band channel , channel 2 , CHBX-TV , CTV , is Very Strong Signal Strength , and will be received by the ANT751 antenna because the Signal Strength Is So Strong.
The weakest signal strength Tv station is WGTQ-DT , Real VHF high band channel 8 , ABC and NBC.
Aim the ANT751 antenna at WABQ.
Aim the ANT751 at about 167 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
As always , the antenna aim and location can be adjusted for best reception.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , Tv's connected.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own , attic , roof , building.
The directions of reception at your location are , South South East and North East.
Install the ANT751 antenna at a location that is clear of obstructions in the directions of reception.
Tvfool is showing that your reception location has a mix of.
NTSC Analog broadcast Tv station channels.
CHBX-TV Real VHF low band channel 2 , CTV.
and
CHCH-TV Real UHF band channel 38 , Independent Super Station.
ATSC Digital broadcast Tv stations channels.
CIII-DT Real UHF band channel 15 , Global.
WWUP-TV Real VHF high band channel 10 CBS and FOX.
WGTQ-DT Real VHF high band channel 8 ABC and NBC.
The Tv will need to channel scan for.
NTSC Analog broadcast Tv channels.
and
ATSC Digital broadcast Tv channels.
DO NOT Channel Scan For Cable Tv Channels.
Last edited by teleview; 21-Aug-2014 at 10:17 AM. Reason: Clarify information and typos.
