Thread: Need some help!
Old 19-Aug-2014, 5:32 PM   #4
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South West , South East.
At no less then 25 feet above ground , and closer to 40 feet and higher above ground will improve reception.
Install a , http://www.antennacraft.net.
HBU44 antenna.
Aim the HBU44 antenna at about 232 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
As always , the antenna aim and location can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
http://www.hollandelectronics.com.
Ronard antenna mounts are Over Built Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 4 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe.
Here are some and not all places to buy antennas and etc.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building in the directions of reception.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
Last edited by teleview; 22-Aug-2014 at 8:01 AM. Reason: Clarify information and typos.
