Old 19-Aug-2014, 4:24 AM   #4
StephanieS
Greetings BuckFinn,
Your map is unfavorable. Any attempt will require your pathway towards Greenville, MS or Memphis being free and clear of all obstacles.
Some have reported the red and gray signals on TVfool maps aren't always accurate. If you did attempt an installation, your baseline would be an expectation that you are in an terrain shielded area and there is a very real possibility you won't be able to lock on any signals.
If you do attempt, purchase from vendors that have generous return policies.
It might be worth a shot if you have open line of sight.... this is one of those situations that you just have to put something in the air and see.
Cheers
