The Signal Strengths are Very Weak Signal Strengths at the reception location.
Do not delete the first tvfool report that is showing 25 feet antenna height above ground.
To see if signal strengths improve with higher antenna heights above ground
please Make and Post 3 more tvfool reports with antenna heights of , 40 , 60 ,
80 , feet antenna heights above ground.
