The Tvfool repot you have posted is not showing any antenna height above ground.
The Broadcast Tv signals are Very Weak Signal Strength.
Do not delete the first tvfool report that is not showing any antenna height above ground.
To see if Signal Strengths Improve with Higher Antenna Heights , please make
and post 4 more tvfool reports with antenna heights of , 25 , 40 , 60 , 80 , feet
antenna heights above ground.
