Old 18-Aug-2014, 10:55 PM   #2
Install the , Clear Stream 2 , antenna Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked by the , attic , roof , building , in the directions of reception.
Know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing Blocking Reception.
The Best Practice for Reliable Reception is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The directions of reception at your location are , West , North West , North , South West , South East.
Here are some , Strong , Sturdy , Long Lasting , above the roof antenna mounts.
The Ronard antenna mounts are Over Built so as to Last a Long Time.
http://www.ronard.com/909911.html. Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
http://www.ronard.com.
Home Depot , has 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that make excellent antenna mast/pipe , the price is low at about 12 dollars.
Aim the CS2 antenna at about , 344 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and Some Digital Tv's also have a Signal Quality Meter.
As always , the antenna aim and location can be adjusted for best reception.
If the , Clear Stream 2 , antenna has the 2 UHF reception loops for reception of the Current UHF channels 14 thru 51.
And has no VHF channels 7 thru 13 , metal rod type reception elements.
Contact.
http://www.antennasdirect.com.
Order and install the , VHF Reception Kit , for reception of VHF high band channels 7 thru 13.
A antenna system amplifier will most likely not be required for , 1 , 2 , Tv's connected.
For more then 2 Tv's connected install a.
http://www.antennacraft.net.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at.
http://www.hollandelectronics.com.
or
http://www.amazon.com
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
To keep Weather/Water out of outside coax connections and devices.
Use coax that has the Compression Type Connectors on the ends of the coax.
Do not use the old type , crimp type connectors.
Do not use coax that has the , molded on the coax type connectors.
Snug Tight coax connections.
To make Double Sure that Weather Water does not get into outside connections wrap with , http://www.coaxseal.com
Last edited by teleview; 19-Aug-2014 at 7:43 AM. Reason: Clarify information and typos.
