Old 18-Aug-2014, 7:08 AM   #2
For reception of , All of the Receivable USA Tv Stations/Channels.
NBC, CBS , ABC , ( PBS - PBS World - Create ) , FOX , CW , MyNetwork , This Tv , Cozi Tv , Antenna Tv , -->And More.
And some Canada Tv Stations/Channels.
At about 25 feet above ground.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South West , West , South South East , East.
Install a.
http://www.antennacraft.net.
HBU44 antenna.
Aimed at about 226 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
As always , antenna aim and antenna location can be adjusted for best reception.
Install a.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at.
http://www.hollandelectronics.com
or
http://www.amazon.com.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own , attic , roof , building.
In other words , the clearer the path from the transmitter to the HBU44 Tv antenna in the directions of reception the better reception will be.
The tvfool radar map shows that the Main Group of Tv stations are to the South West.
With other receivable Tv stations to the , West , South South East , East.
Last edited by teleview; 19-Aug-2014 at 12:52 AM. Reason: Clarify information and typos.
