The TELCO and CATV shown in your photo are connected at the ideal point in your electrical service grounding system. The big box home centers will have split bolt connectors similar to the type used to make the connection for the CATV grounding block. Simply clean all the paint and corrosion off the surface of the electrical service grounding conductor at the point you make your connection.
