Update for the archive. I ordered a y10713 from tdl canada along with a channelmaster balun. The antenna arrived promptly but the balun took several weeks.
I put the antenna up in the attic, resting on the insulation and hooked it up to 25' of rg6. I picked up 9 and 11 beautifully, and 8 is almost always good. 7 (analogue) is grainy but watchable so I'll probably just use that as a backup to 8 since it's the same feed. I might also mount the antenna to see if I get 8 more reliably, but overall I'm happy with the results. No luck on 13, but since it's a French channel, I don't mind.
Overall I would recommend trying an attic installation of a y10713 to someone in Moose Jaw to get the Regina channels.
