Old 15-Aug-2014, 11:01 PM   #6
To Improve and Stabilize Reception and Receive more Digital Broadcast Tv Stations/Channels.
Install a , Antennas Direct , DB8e , current UHF Tv channels 14 thru 51 antenna.
http://www.amazon.com.
Aim the DB8e antenna at about 50 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Also install a.
http://www.antennacraft.net.
Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 242 degree magnetic compass direction.
Install the Y10-7-13 antenna about 3 feet below the DB8e antenna on the same antenna mast.
Install a.
10G221 preamplifier.
Connect the DB8e UHF antenna to the UHF connection of the 10G221 preamplifier.
Connect the Y10-7-13 VHF high band antenna to the VHF connection of the 10G221 preamplifier.
By the , HFS-2D , HFS-3D , splitters at.
http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html. Install the , ronard(911), 5 foot triopd antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building , in the directions of reception.
The directions of reception at your reception location are , North East , North , East , South West.
The Y10-7-13 VHF high band channels 7 thru 13 antenna is aimed to the South West for reception of.
WTVC , Real VHF high band channel 9 , ABC and This Tv. http://www.thistv.com
WRCB , Real VHF high band channel 13 , NBC and Antenna Tv. http://antennatv.tv
And also receive the stronger signal strength Tv stations to the , North East , East , at/through the back and back angles to the Y10-7-13 antenna.
WBIR-DT , Real VHF high band channel 10 , NBC and Me-Tv.
WKNX-Tv , Real VHF high band channel 7 , Independent and Daystar.
WJDP-LD , Real VHF high band channel 11 , Religion.
Last edited by teleview; 16-Aug-2014 at 6:19 PM. Reason: Clarify information and typos.
