Old 14-Aug-2014, 6:17 AM   #11
Not all is bad with the Canada Broadcast Tv Situation.
The Big Cities of Canada along the Canada-USA border have Many Canada Digital Broadcast Tv Stations/Channels and also USA Digital Broadcast Tv Stations/Channels to receive.
At your location , If you will like to Test for reception of , CBRT , Real UHF channel 21 , CBC .
CBRT UHF channel 21 is a Digital Broadcast Tv Station/Channel.
At about 40 feet above ground , install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna.
With a , http://www.antennacraft.net.
10G201 preamplifier.
Aim the DB8e , UHF antenna at about 175 degree magnetic compass direction.
As a Test of reception run the coax through a open door or window direct to 1 Tv.
Last edited by teleview; 14-Aug-2014 at 10:04 PM. Reason: Clarify information and typos.
