Old 13-Aug-2014, 9:46 PM   #7
Antenna system #1.
A simple antenna setup that will provide good reception.
Install a.
http://www.antennacraft.net.
AC9 antenna.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , West , South South West , South , North East , North West.
Aim the AC9 antenna at about 225 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna/s , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
_____________________________________________________
Antenna system #2.
A improved antennas setup for better reception.
Do not install the AC9 antenna.
In place of the AC9 antenna.
Install a , Antennas Direct DB8e , current UHF channels 14 thru 51 antenna.
Aim 1 panel at about 265 degree magnetic compass direction.
Aim the other panel at about 190 degree magnetic compass direction.
And
About 3 feet below the DB8e antenna on the same antenna mast install a.
CS600 , VHF channels 2 thru 6 antenna.
Aim the CS600 antenna at about , 225 degree magnetic compass direction.
Combine the DB8e UHF antenna and CS600 VHF antenna with a.
UVSJ= UHF/VHF - Separator/Joiner.
#EU385CF.
http://www.amazon.com/Antennas-Direc...n/dp/B008PBTPN.
Connect the DB8e UHF antenna to the UHF connection of the UVSJ.
Connect the CS600 VHF antenna to the VHF connection of the UVSJ.
The remaining connection of the UVSJ , a coax goes out to the Tv/s.
As a Test.
Antenna systems 1 and 2 can be Tested reception with a , Winegard ,
LNA100 Boost , antenna system amplifier connected and not connected.
http://www.amazon.com.
If only 1 Tv is connected Do Not use a splitter.
If more then 1 Tv is connected.
The amplifier will be connected -->Before<-- any splitter.
Here are some Above the Peak of the Roof antenna mounts.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Also Know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building , in the directions of reception.
Absorbing and Blocking Reception.
The Best Practice is to install the antenna/s at a location that has the least amount to no amount of obstructions in the directions of reception including your own , attic , roof , building , in the directions of reception.
At your reception location the directions of reception are , West , South South West , South , North East , North West.
If the Tv antenna/s need to be installed at a location that provides better unobstructed reception in the directions of reception , that is not above the roof of the building , then might have to install the antenna/s at a better location.
Yes it is Ok to Test reception above the roof of the building first.
Last edited by teleview; 15-Aug-2014 at 7:13 AM. Reason: Clarify information and typos.
