Old 15-Dec-2010, 4:32 PM   #10
dprljackson
OK - I've decided to go with the Winegard 9032 and a channel master CM-7777 pre amp. If this brings in FOX reliably, I'll worry about exactly how to get everything else at the same time. Might require a second antenna. But first things first. We'll see how the 9032 does. I'll let you know the results.
David
dprljackson is offline   Reply With Quote
