Old 12-Aug-2014, 6:32 PM   #11
As I understand it , the Stellar Labs / MCM #30-2430 , UHF antenna is installed at about ground level and aimed at Colorado Springs.
The #30-2430 UHF antenna is a same type and kind of antenna as the DB8e UHF antenna.
Not knowing the condition of or make and model of the VHF/UHF antenna that , tydeck77 has.
I recommended discard the VHF/UHF antenna and install the , Y10-7-13 , DB8e , for maximum reception.
Yes the VHF/UHF antenna can be used to Test for and reception of the Denver and Colorado Springs Tv stations.
For the best reception , it is Important to install any antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
