Old 12-Aug-2014, 6:09 PM   #6
Quote , "(I do not want to be able to see it from the front of the house."
= Aesthetics , A variation of the word Anesthetics.
The Truth is Tv Antennas are Beautiful and Handsome.
The Tvfool Radar Plot Shows the Main Groups of Digital Broadcast Tv Stations/Channels are to the , North West , North , South South East.
Attics and the inside of buildings Are Not a reception friendly environment and Never Will Be an reception friendly environment.
Yes you can start with a antenna in the attic.
http://www.antennacraft.net.
HBU33 antenna.
Aimed at about 350 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and Some Digital Tv's also have a Signal Quality Meter.
The Tv reception is signal strength is Ok at your reception location.
You can also Test reception with a.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
If reception situations happen in the attic that are not resolvable with antenna aim and location adjustments and preamplifier.
Then move the HBU33 antenna and preamp to Above the Peak of the Roof in such a manner that the , attic , roof , building , are not , obstructing , impeding , blocking , reception in the directions of , North West , North , South South East.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around rthe chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Install the HBU33 antenna Above the Peak of the Roof.
Absorbing Blocking Reception.
The Best Practice for Reliable Reception is to install the HBU33 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
If installing the HBU33 antenna at some other location then the roof will provide the , least amount to no amount of obstructions of any type or kind in the directions of reception then install at that location.
Last edited by teleview; 13-Aug-2014 at 2:41 AM. Reason: Clarify information and typos.
