Thread: Antenna Advice
Old 12-Aug-2014, 6:11 AM   #11
Above the Peaks of the Roofs of the house and gararge and any other building/s in such a manner that reception is not , obstructed , impeded , blocked , by the , attics , roofs , buildings , in the directions of , North West , West , South West , South , East.
Install a.
http://www.antennacraft.net.
HBU44 antenna aimed at about 298 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
The following information is important.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attics , roofs , buildings , in the directions of reception.
Absorbing Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attics , roofs , buildings , in the directions of reception.
If a better location of reception means that the antenna will be installed at some other location after the Test of reception on the roof then move the antenna after the Test of reception on the roof.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Last edited by teleview; 13-Aug-2014 at 6:47 AM. Reason: Clarify information and typos.
