Old 12-Aug-2014, 12:58 AM   #10
As time goes by , More Broadcast Tv Stations and Channels will most likely be added for reception at Red Deer.
For reception of the Local Tv stations/channels , tvfool shows a mix of Digital and Analog Tv Stations/Channels.
Install a.
http://www.antennacraft.net.
AC9 All Channel Antenna.
Install the AC9 antenna above the Peak of the Roof about 25 feet above ground in such a manner the reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the direction of , East.
Aim the AC9 antenna at about 90 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
A antenna system amplifier is not required.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
It will be interesting to receive and monitor and be involved in the Broadcast Tv situation.
A coax can be run to a Tv to 'Monitor' the situation.
The Tv will need to channel scan for , NTSC Analog and ATSC Digital Broadcast Tv Stations/Channels.
DO NOT Channel Scan For Cable Tv Channels.
Here is a article about the situation that Canada is in with Broadcast Tv.
http://www.tvtechnology.com/feature-...-track/206775..
As in the USA , the Free Broadcast Tv Stations/Channels , The frequency spectrum that is , UHF channels 69 thru 52 , are removed from Tv service and sold to the Cell Phone and Wireless Internet businesses.
The Canada government made Billions of dollars on the sale and did not provide even one penny to the Tv stations / broadcasters.
In the USA the Tv stations/broadcasters received a slice of the Billions dollars Pie.
I am aware of what is happening in Canada , many Carpet Baggers in Canada.
A lot of corruption in the USA and many receive a slice of the corrupt pie.
The many does not include me.
Last edited by teleview; 17-Aug-2014 at 9:55 PM. Reason: Clarify information and typos.
