Old 11-Aug-2014, 2:15 AM   #11
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South East , South , South West , North.
Install a , http://www.antennacraft.net.
HBU11K antenna.
Aimed at about 147 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv'
s also have a Signal Quality Meter.
--->A antenna system amplifier is Not required.<---
If you own the outside wall.
If you own the roof.
( And if as an example of antennas on the outside of the building , if their are any of those small satellite dishes any where on the outside of the building.)
Here is the Federal Antenna Law that says Yes you can install the HBU11K Broadcast Tv antenna on the outside of the building and roof.
http://www.fcc.gov/mb/facts/otard.html.
Do not use this antenna recommendation of the HBU11K antenna because it is a small size of antenna , that a small size antenna is the only size antenna that can be installed.
The Federal Antenna Law , Clearly States that a Broadcast Tv Antenna of Any Size can be installed outside so as to have Reliable Reception.
The reason the small HBU11K antenna is recommended for your reception situation is because the Tv Reception is Very Strong Signal Strength.
