Thanks so much for taking the time to explain the output power situation. Im learning a lot. Although i am intrigued at what might be accomplished by attempting to finalize an attic installation, i decided to take it outside today and placed it in an easy to access area of this "sub roof" where the antenna was approx 15 feet off the ground but had no obstructions aside from trees (i was alone so decided not to risk climbing to the highest point of the roof with the antenna for this test) and i received all channels that my TVFool report mentioned with the exception of ABC. I see now that ABC might be tricky since it is a weaker signal and there are co channel and adjacent channel warnings as well. I will be looking for a tripod and mast to mount it on the roof in the near future. If you have any suggestions for tripods and masts that deliver to the Montreal area i'm all ears.
Thanks again for your time
