Old 11-Aug-2014, 1:09 AM   #7
emartz91
Larger antenna aimed at 10 degrees magnetic. One that is directional but still a wide beam width. You would pick up all stations in green and maybe some yellow ones. The back of antenna will provide sufficient gain for south group in green. The attic is an unpredictable reception environment. Good luck
emartz91 is offline   Reply With Quote
