Thread: Best Approach
Old 10-Aug-2014, 12:59 AM   #6
CFCF is strong signal strength.
The antenna is in the attic.
Attic's Increase Multi-Path.
The multi-path can effect some channels more then others , the effect is highly variable.
Multi-Path is Tv signal bouncing all around in the attic and bouncing off you and when you move around this changes the multi-path.
Multi-Path in attics is Not Good for Reliable Reception.
A amplifier connected to the antenna in the attic will make the reception Worse.
Reason: A antenna system amplifier connected to a antenna that is in the attic
will amplify the multi-path Tv signal bouncing all around in the attic along with
the main direct signal.
Antenna system amplifiers can not tell the difference between reflected signals and main signal.
Amplifiers amplify what ever is fed to it.
To improve reception move the antenna to a location that has the least amount to no amount of obstructions of any type or kind in the direction/s of reception.
Obstructions to reception are , attic , roof , building , trees , tree leaves , plants , plant leaves , hills , mountains , bill boards , signs , tractors , UFO's , and any thing else that is in the way of and is obstructing reception in the direction/s of reception.
