Old 9-Aug-2014, 9:54 PM   #8
tydeck77
Thanks for the reply and your continued advice.
As a last resort I moved the antenna off the roof and placed at ground level as far away from the pine trees as I could.
And I'm in business!
I'm pulling CBS, ABC, FOX, and CW from Colorado Springs.
Still waiting on the pre-amp to be delivered, so I'm hoping there are some NBC signals hiding in there.
2 other questions if you don't mind.
I never realized just how much loss there is in the signals, but I'm not currently able to split the signal. Are the splitters you recommended helpful there?
If there is no NBC in the coax I may put the old antenna back on the roof since I was getting that VHF Denver channel there. Is there a good coupler/joiner you would recommend?
The goal would be to get all signal in 1 coax so I can run it through a Simple.TV but not a deal breaker.
Again, thank you!
tydeck77 is offline   Reply With Quote
