Thread: Guidence Needed
Old 9-Aug-2014, 9:20 AM   #4
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South West , West North West , North East , South East.
Install a.
http://www.antennacraft.net.
HBU44 antenna.
Aimed at about 240 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone compass , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a.
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html. Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , makes good antenna mast/pipe , the price is low at about 12 dollars.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast TV Reception in the directions of reception including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for reliable reception is the install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The directions of , South West , West North West , North East , South East.
