Old 8-Aug-2014, 11:34 PM   #4
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South East , South , South West , West , North West.
Install a , Antennas Direct , DB8e , current UHF channels 14 thru 51 antenna.
http://www.amazon.com.
Aim 1 panel of the DB8e antenna at about 170 degree magnetic compass direction.
Aim the other panel at about 280 degree magnetic compass direction.
Here ia how to aim antenna/s , http://www.kyes.com/antenna/pointing/pointing.html.
Use a Real and Actual magnetic compass to aim antenna/s , do not trust a , cell phone , tablet , etc. compass.
As always , a Tv antennas aim direction can be adjusted and the antenna location can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a.
http://www.antennacraft.net.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitter at , http://www.hollandelectronics.com, or , http://www.amazon.com.
The antenna system Must Not Be Connected to Internet Cable Coax in any way shape or form.
The antenna system Must Not Be Connected to Active Cable Coax in any way shape or form.
Yes , coaxes that are in or on the house can be used for the antenna system.
The coaxes that are used for the antenna system must not be connected to internet or cable service.
Do not connect the (eda2100) drop/distribution amplifier.
http://www.ronard.com/909911.html. Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html . Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
