Old 8-Aug-2014, 10:36 PM   #3
A Simple Reception Situation , that requires big antennas.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building.
Install a , Antennas Direct , DB8e , Current UHF channel 14 thru 51 antenna.
http://www.amazon.com.
Aim 1 panel at about 350 degree magnetic compass direction.
Aim the other panel at about 320 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet or etc. compass.
As always , the antenna aim and antenna location can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a.
http://www.antennacraft.net.
Y10-7-13 , VHF high band channels 7 thru 13 antenna.
Aim the , Y10-7-13 VHF high band antenna at about 317 degree magnetic compass direction.
Install a.
10G221 preamplifier.
Connect the DB8e , UHF antenna to the UHF connection of the 10G221 preamplifier.
Connect the Y10-7-13 VHF antenna to the VHF connection of the 10G221 preamplifier.
By the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html. Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that make good antenna mast/pipe , the price is low at about 12 dollars.
Install the Y10-7-13 antenna about 3 feet below the DB8e antenna on the same antenna mast/pipe.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building in the directions of reception , West , North West , North.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The directions of reception are , West , North West , North.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
DO NOT Channel Scan for Cable Tv Channels.
Last edited by teleview; 11-Aug-2014 at 6:59 AM. Reason: Clarify information and typos.
