Old 8-Aug-2014, 5:34 PM   #1
Hickorync
Antenna Suggestion Complete Setup
We just cut the cord and are looking to purchase a antenna for our house. I plan on mounting a 7 foot mast to our brick chimney stack which should give a total height of 25 ft above ground level. I was hoping to be able to tie the antenna into our main cable line which would feed to 5 TV's. We already have spliter's setup to run to the connections from our previous cable connection to the TV's.
My problem is... I have no idea what type of setup I need. I was looking at the DB8 but I am not sure if that will be sufficient for our needs. I like the ease of operation and the need to not have a rotor but that may be wishful thinking.
Any help on Antenna recommendation, amplifier's needed, etc, would be greatly appreciated. Basically a complete setup from scratch. Football is around the corner and live sports is the main need for the antenna.
Link to TVFool Report: http://www.tvfool.com/?option=com_wr...e1c6a16d69eb9f
Thanks!
Hickorync is offline   Reply With Quote
