Old 8-Aug-2014, 2:10 PM   #6
stvcmty
Originally Posted by magtag12345@yahoo.com View Post
located at the GPS co-ordinate 37°32'32.67"N,121°59'21.53"W
I think that is 37.54241, -121.98931 in decimal. http://www.satsig.net/degrees-minute...calculator.htm
The plot at 25’ is then:
http://www.tvfool.com/?option=com_wr...e1c60320490b1b
If that is the correct plot, I would put a HBU11 up and start with it pointed at 116 degrees true. The HBU 11 should get the stations from 292 and 300 from the back, and it should have enough beam width to get channel 8. There are so many strong signals I would not use a preamp. Instead I would use a distribution amp if more than a 2 way split was needed. If KBKF-LP (RF6) is desired, a FM6 or Y5-2-6 pointed at 165 degrees true could be added with a HLSJ.
stvcmty is offline   Reply With Quote
