Old 8-Aug-2014, 5:43 AM   #7
I am not saying it is hopeless.
The Best practice for Reliable Reception is to install antenna/s at a location that has the least amount to no amount of obstructions in direction/s of reception.
The closer obstructions are in the direction/s of reception the more disrupted reception will be.
The further obstructions are away from the antenna/s in the direction/s of reception the better reception will be.
The Current Broadcast Tv Stations/Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has Receivable Broadcast Tv Stations/Channels in the.
The Y10-7-13 antenna is for reception of VHF high band channels 7 thru 13.
The DB8e antenna is for reception of UHF Tv channels 14 thru 51.
You have the , Stellar Labs / MCM - #30-2430 antenna that is the same type of antenna as the , DB8e .
So use the Stellar Labs / MCM #30-2430 in place of the DB8e .
