Old 15-Dec-2010, 3:41 AM   #6
Justintoxicated
Originally Posted by John Candle View Post
Looks like you are correct about UHF 23 to the south , so go with the HD7698P. But then FCC Tv channel assignments are still in progress and a VHF low band channel 2 thru 6 might appear in your area. Here is more information on towers http://forum.tvfool.com/showthread.php?t=1045
Thanks for the link that square tubing looks cool.
If I got the HD7698P, what direction would you recommend pointing it? Directly at the VHF stations at 201 degrees, and hope that I can still get all of the UHF stations? Or did you mean with the rotator?
So, in your opinion, it would not be a good idea to get the A-1713 and a UHF Specific antenna?
Justintoxicated is offline   Reply With Quote
