If this is what is causing the interference,
Probably, if you are having problems as trains pass through.
No, you already have an amp but it's of unknown quality.
I believe there is already 32db amplifier built in.
They probably lied about that, too.
just a 4 way splitter and that didn't work.
If you put the splitter between the amp and its power supply, you deprived the amp of its power and turned it into a brick. At least, as a brick, we know what to expect from it.
If I have to choose between powering through interference over splitting,
That isn't a choice since the amp will amplify the interference also.
You have a number of very local signals. Most amps will overload and cause loss of received signal.
We all were at some point. I bought my share of Radio Shack junk back in the day.
Are you able to identify which of those local translators are being received? Are you receiving any of the direct signals from OK City?
