Old 15-Dec-2010, 3:00 AM   #3
If the attic has an access opening in the ceiling in the house or car port or garage , and if the antenna would be in a good place for reception over that opening the you could put a antenna mount there. Some common antenna mounts are tripod mounts , chimney mounts , eave mounths , push up pole mounts with guy wires , or you can make a new block mount with a pole and guy wires like shown in the picture. http://www.solidsignal.com
