Old 6-Aug-2014, 11:26 PM   #2
Above the Peak of the Roof install a.
http://www.antennacraft.net.
HBU44 antenna aimed at about 152 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and Some Digital Tv's also have a Signal Quality Meter.
Install a.
http://www.antennactaft.net.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Here are some Above the Roof antenna mounts.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/ychm.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
For coax that is exposed to the weather outside.
Use coax that has the Compression Type Connectors on the ends of the coax , so as to keep water out of the connectors and coax.
Do not use coax that has the crimp type connectors.
