The difference in UHF performance for the 8-bay vs the UHF section on the HD8200 is slightly in favor of the HD8200. The VHF 7-13 performance is also better than the Antennacraft Y10713, by about 2 dB.
with the HD8200 -- one antenna instead of two on the mast = less wind load and if a rotator has to turn it, it will like you better and you will be able to get to see channel 6 and possibly 2.
Go with the HD8200.
