Old 6-Aug-2014, 7:35 PM   #3
Geezer64
Originally Posted by elmo View Post
I'd believe that the antenna is easily capable of tuning those channels for you. Given the length and the 4 tuner split, the preamp should be pretty good for the job. Myself, I'd like to check signals with and without and see how it differs. I would expect higher signal strength given your setup. The distance to the pines wouldn't make me think they'd be a major factor. Do you know the exact aim of the antenna? I'm assuming you had the tuner rescan completely once connected too. How about taking the Tivo out of the test and connect direct to the TV and rescan there. Check the signal strengths and see what you get. If you are currently checking signal strength w/in Tivo, you can't exactly compare the two.
Thanks Elmo. Looks like the antenna is pointing about 350 degrees but this is looking at it from ground level since I cannot get on the roof. I have scanned the channels into my TV, which is a Samsung PN60E but it does not indicate signal strengths.
Geezer64 is offline   Reply With Quote
