Old 6-Aug-2014, 6:38 PM   #5
The Tv reception is Very Strong Signal Strength at your reception location.
Do Not use any type or kind of antenna system amplifier.
Disconnect and Remove All Parts of Antenna System Amplifiers.
As a Test of reception to prove reception , install the CS2 antenna above the roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South West , North.
Aim the CS2 antenna at about 212 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
As always , the antenna aim and location can be adjusted for best reception.
Most Digital Tv's have Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
---->To Prove Reception<----
-->Connect a NEW Continues Length of RG-6 Coax to the CS2 antenna and Run
the NEW Continues Length of coax through a open door or window direct to 1
Tv.
No splitters , No couplers , No amplifiers , No etc. .
The Tv Must Channel Scan for the , OTA=Over The Air , ATSC Digital broadcast
Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels
~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv
transmissions travel through the Air from the transmitting antenna to the
Receiving antenna.
DO NOT Channel Scan For Cable Tv Channels
Because the Tv reception is so Strong at your reception location.
A Simple antenna that can be install in place of the CS2 antenna is the.
http://www.antennacraft.net.
HBU11K antenna.
