Thanks for all the replies. How far away can I have the antenna before I lose too much signal. I have a detached garage about 100 feet away, the peak is only about16' but the tree line is much farther away. The treeline from the house is only about 30 feet.
I have a conduit under ground to the house that I could run cable through and in the basement I have coax that the electrician ran for 4 different tv's, I could install a splitter at that spot
Thanks Again
al
