Old 15-Dec-2010, 2:20 AM   #2
John Candle
Tv Antennas and Reception
Looking at the Pending Applications Included , I recommend Winegard HD7084P antenna. I do not think you will need a rotor as there is only a 26 degree spread of the angle of Tv stations to the south. You do have XETV Tv 6 to the south. Might as well cover all the channels , 2 thru 6 , 7 thru 13 and 14 thru 69. This all channel antenna will cost the same or less then a antenna that receives 7 thru 13 and 14 thru 69.
