Old 6-Aug-2014, 5:10 PM   #2
If you had that kind of problems with a C2, then either the attic or the signal path is killing the signals before they get to the antenna.
What type of roofing is on your home? Radiant barrier present?
Have you tried it without the Rocketfish, just a single coax from the antenna to a single set?
