Old 6-Aug-2014, 6:19 AM   #45
I would expect the CM-7777 would be overloaded due to the powerful signals from Gold Mt. (KCPQ, KTBW & various FM stations). The TVPRAMP1R may have slightly better noise performance, but not enough to make me believe that you would see a noticeable improvement in signal quality as compared to the PCT amp.
I believe that your problem is not primarily one of raw signal strength... But rather an issue of quality. Just as a water pump can not make dirty water clean when it increases the pressure, an amplifier amplifies both the signal and any interference received by the antenna.
I believe you'll have better success experimenting with antenna location and/or elevation.
