Well, I haven't had time to raise the antenna and cut some trees but I did try aiming the antenna in different directions. When pointed SW looking over our hay fields (no trees!) we picked up 5 stations. All other directions were unsatisfactory. My question is -- is it possible to use one antenna pointed towards the NW to get channel 24 (Erie) and WPSU Clearfield ( on the back side) and another antenna pointed to the SW for the 5 stations I wasn't aware were obtainable? If so would you please explain how this is done? I have another antenna identical to the Terrestrial DB8 but is a Channel Master which we used at our previous home.
