Old 6-Aug-2014, 1:04 AM   #9
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , North , North East , East , South East , South , South West , West.
Install a.
http://www.antennacraft.net.
Y10-7-13 , VHF high band channel 7 thru 13 antenna.
Aim the Y10-7-13 antenna at about 11 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
About 3 feet above the Y10-7-13 antenna on the same antenna mast.
Install a , Antennas Direct , DB8e , current UHF channels 14 thru 51 antenna.
http://www.amazon.com.
Aim 1 panel at about 31 degree magnetic compass direction.
Aim the other panel at about 129 degree magnetic compass direction.
Install a , http://antennacraft.net.
10G221 preamplifier.
Connect the Y10-7-13 VHF antenna to the VHF connection of the 10G221 preamp.
Connect the DB8e UHF antenna to the UHF connection of the 10G221 preamp.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception.
Absorbing and Blocking Tv Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
