Old 5-Aug-2014, 10:29 PM   #7
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , East , North East , North , South East.
Install a , Antennas Direct , DB8e , current UHF channels 14 thru 51 antenna.
http://www.amazon.com.
Aim 1 panel at about 65 degree magnetic compass direction.
Aim the other panel at about 110 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
As always , the antenna aim and location can be adjusted for best reception.
Also about 3 feet below the DB8e antenna on the same antenna mast.
Install a , Winegard HD5030 , VHF channels 2 thru 13 antenna.
Aim the HD5030 at about 92 degree magnetic compass direction.
It looks like.
http://www.warrenelectronics.com.
Has the HD5030 in stock.
http://www.warrenelectronics.com/antennas/HD5030.htm.
Install a.
http://www.antennacraft.net.
10G221 preamplifier.
Connect the DB8e UHF antenna to the UHF connection of the 10G221 preamp.
Connect the , HD5030 VHF antenna to the VHF connection of the , 10G221 preamp.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Here are some above the Peak of the Roof antenna mounts.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html , Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch lengths of 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Last edited by teleview; 13-Aug-2014 at 7:50 PM. Reason: Clarify information and typos.
