Old 5-Aug-2014, 6:03 PM   #3
stvcmty
You said you get CW on (virtual) channel 2. WKTV, real channel UHF 29, has NBC on channel 2.1 and CW on channel 2.2, so I assume that is what you are getting. That makes sense, it is the strongest UHF station on your plot.
What types of antennas have you tried? Indoor, outdoor, un-amplified, amplified?
Many antennas would be a poor choice for the signal report you attached, you have a VHF-low station on RF6. Also, there appears to be a good bit of co channel interference at your location. You probably need a big antenna; wide side to side for VHF low stations, and long front to back for a tight pattern to reject unwanted signals.
What is your goal? Do you want an ABC, CBS, NBC, Fox, CW, PBS?
If I lived where you live, I would put a winegard HD7084P all band antenna pointed at 79 degrees true as high as possible with a RCA TVPRAMP1R.
