Old 5-Aug-2014, 3:09 PM   #5
stvcmty
Do you have issues watching RF7 at night? Is this a problem that needs to be fixed?
Originally Posted by tv454481 View Post
Setup is an AntennasDirect DB8e with the VHF retrofit kit, fed into a Winegard HDA-200 distribution amp.
The VHF retrofit kit is just a dipole. A dipole has a very wide reception pattern. If there is noise anywhere in front or behind the dipole, the dipole will pick it up with the RF7 signal. The only places the dipole will not pick up noise are in the directions the elements point to. You have great signal predicted on your TV fool plot, but if the quality drop/signal to noise drop on RF7 is a problem, a more directional antenna could help.
You could play noise detective and find the device that is causing the noise after dark, but the FCC does not seem to be doing much to enforce part 15 rules, so you would be on your own.
Both RF 7 and RF 9 are on the same heading from you, so any VHF-high antenna would work, the Y5-7-10 would be much more directional than a dipole and it is inexpensive and not obnoxiously long.
HDHomerun tuner
In my experience, the HDHR is very picky. I have a HDHR and a Hauppauge HVR-1600 in a WMC computer. The HVR-1600 gives me 1 more bar on channel scan for most channels. There are channels that the HDHR can’t get that the HVR-1600 can get reliably. I think the difference is how well the HDHR vs the HVR-1600 handle noise and multipath.
Your TV fool plot says the path to WSAW RF7 is LOS, but if something in the path is getting blown around at night, that could be part of what you are seeing. A more directional antenna could help with multi path if that is part of the problem.
Unless the quality drop is hurting your ability to watch WSAW, no action is required.
stvcmty is offline   Reply With Quote
